Message 1 of 2
email blocked
My BT email account was blocked because of a suspected security threat. I've reset my password through BT's recovery process and webmail works, but IMAP and SMTP authentication still fail on both my MacBook and iPhone. Can you check whether the security restriction has been fully lifted for email applications?
1 REPLY 1
Message 2 of 2
Re: email blocked
Make sure when you changed the password on your Apple devices you are using the correct settings.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
