Message 21 of 25
Re: export bt mail data to another provider
Yes, sorry, I assumed you were going to continue to use Thunderbird. You can export your BT contacts list as a CSV file in webmail and then import the file to Gmail.
Message 22 of 25
Hi. Thank you very much for all your patience and help.
I am now there thanks and hopefully will not need to trouble you further
Message 23 of 25
No worries, glad you got it sorted.
Message 24 of 25
Hello,
I thought it might be useful to everyone else struggling to migrate their BT Connect e-mails over to another system, these guys have just helped me out -
Search for Hosting Matters
They have just managed to copy all of my e-mails from my BT Connect account over to a new one and it was all very stress-free from my end!
Message 25 of 25
As this is the BT residential forum, nobody here will have a BT connect email address.
