Message 1 of 12
iPad app problem after password change
Since changing my password the mail app on my ipad receives email but can no longer send, all attempts end in the Outbox.
Send and receive work OK on Webmail
I am a broadband customer so have Standard email
What could be the problem?
11 REPLIES 11
Anonymous
Not applicable
Message 2 of 12
Re: iPad app problem after password change
if you changed the password on bt email you will need to make this change on the device to continue receving email if you havent done so
email settings
Message 3 of 12
When you change your BT password on an iPhone/iPad/Apple device it may only change for INCOMING mail.
To change the outgoing mail password you have to go into Settings; then scroll down to Passwords & Accounts or on older devices Mail, Contacts, Calendars. From there select the BT email account and select the account where it is listed under IMAP.
You will find the details for the account and can change the password for the Incoming server there, the outgoing mail server only shows SMTP and mail.btinternet.com You have to tap on that Primary Server in order to find where the Outgoing password is hidden so you can update it.
When setting up the email account on your device you are best to set it up manually, using "other" and ensure that you are using the correct settings as per this link.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Message 4 of 12
Thanks. Yes, I did change the password on both the device app settings as well as on the webmail.
The app lets me login on the new password and receive msgs so I don't know why I can’t send.
Message 5 of 12
Well Thankyou for your suggestion. I changed to the new password in the Primary server section and can now send successfully.
However, I no longer receive messages (at least not test ones that I send to myself-which used to be ok)
Message 6 of 12
Hi again. Further to my earlier response I confirm that I can now send from the Mail app but cannot receive msgs sent by others. I can still send and receive using Webmail.
Any further clues ?
thanks
Will
Message 7 of 12
Hey @Willmouger, thanks for sharing those details for us!
I've flagged this with our email support teams, but just to be sure can you please confirm exactly what settings you have showing for each section in the iPhone email app?
Feel free to upload a screenshot if that's easiest, but make sure to mask any personal information.
Peter
Message 8 of 12
Thanks for your reply. I’ve attached two screenshots showing settings. The others are too big but they show the following..
IMAP ACCOUNT INFORMATION
Name
Email
Will
w**********@btinternet.com
Description Btinternet
INCOMING MAIL SERVER
Host Name mail.btinternet.com
Username w**********@btinternet.com
Password
OUTGOING MAIL SERVER
SMTP
mail.btinternet.com
and…….
• Account Settings
Advanced
Archive Mailbox
MOVE DISCARDED MESSAGES INTO:
Deleted Mailbox
Archive Mailbox
DELETED MESSAGES
Remove
INCOMING SETTINGS
Use SSL
Authentication
IMAP Path Prefix /
Server Port 993
Message 9 of 12
You might want to edit out your email address before you attract more scammers and spammers that you can deal with!!!
Message 10 of 12
Thanks @Willmouger, I've shared this with our team, and if there's anything more I need in the meantime I'll let you know.
Just as a heads up too, I've edited your post so that your email address isn't visible in public, as we recommend not sharing this.
Peter
