Message 1 of 3
iPhone Mail App issue
Hi, I’m having problems with my email account on the iPhone Mail app. I have deleted the account, switched off my phone and then added the account again.
I am getting a message to say “the imap server doesn t support password authentication. Please check your account settings and try again”. I then input all the details manually and click next but getting a message saying “cannot connect using ssl”
Can anyone please help. I have set up my BT Mail app with the same settings and that is fine. I can also access my email on webmail so username and password are correct. I have been going round in circles all morning. I’m clearly doing something wrong but not sure what. I have two email accounts (one BT one Outlook) so want to use the iPhone mail app to have them both on the same one.
Many thanks
2 REPLIES 2
Message 2 of 3
Re: iPhone Mail App issue
Are you a BT Broadband customer?
Just to check that you are using the correct settings are as per the following link and ensure you have not selected password authentication.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Message 3 of 3
Thanks gg30340
I have been able to resolve the issue. I had a vpn switched on and that was causing the issue. I have switched it off and everything is working fine.
Thanks again
