Message 1 of 7
images on emails
for some reason I no longer get images on my emails just a tiny box.  I have got the allow images box ticked so unsure why this has happened.
6 REPLIES 6
Message 2 of 7
Re: images on emails
Is that when using an email client or a browser? If browser then it could be the security settings are too high and are preventing the image from being downloaded
Message 3 of 7
just when using bt mail
Message 4 of 7
Understood but how are you accessing BT email, are you using an mail client (e.g. Outlook) or an internet browser (e.g. Microsoft Edge or Google Chrome)
Message 5 of 7
i go in via microsoft edge i am not using outlook on my lap top
Message 6 of 7
Check your Privacy, Search and Services setting in your browser, I suspect you have it set to Strict, balanced should be adequate for most people.
I strongly suspect that the tiny box you refer to is what is known as a place holder, it's where a picture would be displayed where the security setting on your browser allowed images to be downloaded.
Message 7 of 7
thank you, you were spot on somehow it had changed from balanced to strict.  Must have clicked on it by accident.
