Message 11 of 18
Re: Inbox Issue
Didn’t know how to reopen the closed one
Message 12 of 18
Re: Inbox Issue
Threads don't get closed, you can always post on a thread. I'll unmark it as resolved if you like.
Message 13 of 18
Re: Inbox Issue
Yes please
Message 14 of 18
Re: Inbox Issue
Obvously by the fact I have moved over 130 emails using the method I posted the BTMail does aĺlow more than 10 emails at a time contrary to what you have said.
What device operating system and web browser are you using?
Have you tried using a different browser?
What happens when you use either of the methods as described?
Do not try and move them all at the same time. Try 100 at a time.
Message 15 of 18
Re: Inbox Issue
Same issue with Firefox
Message 16 of 18
Re: Inbox Issue
Can’t highlight more than 10 either by tick box or  shift key with chrome. Windows 11 laptop.
Message 17 of 18
Re: Inbox Issue
Once again I have carried out a test this time using Chrome and Firefox, the last one was with Edge, and I have just moved 150 emails using both the methods I have posted about.
When you click in the small box at the left of the first email are you holding the shift key down when you scroll down to the last email using the scroll bar at the right hand side, then click on the last email you want to include?
Message 18 of 18
Re: Inbox Issue
Can’t use your methods but have just used shift key and page down to highlight and delete 100+. Would prefer a better bulk option if anyone can come up with one.
