Message 1 of 13
security
Not sure if put in right board
When I click on email or my bt it comes up with a triangle and the following:-
Warning: Potential Security Risk Ahead
Firefox detected a potential security threat and did not continue to signin1.bt.com. If you visit this site, attackers could try to steal information like your passwords, emails, or credit card details.
What can you do about it?
The issue is most likely with the web site, and there is nothing you can do to resolve it. You can notify the web site’s administrator about the problem.
What should I do? Thans Jules
12 REPLIES 12
Message 2 of 13
Re: security
I have the same problem. It's annoying.
Message 3 of 13
Re: security
I also get
Your connection is not private
Attackers might be trying to steal your information from signin1.bt.com (for example, passwords, messages or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID
Message 4 of 13
Re: security
Seeing the same message in 3 different browsers. On top of all the other issues I'm now be warned not to connect to BT email at all because it's not safe to do so.
Chrome, Edge & Firefox all now show warnings that privacy will be compromised if you continue to the BT email site.
BT email  not secure warning message.BT email not secure warning message.
Message 5 of 13
Re: security
I have my BT email on my iphone, my work pc and home pc. I am currently in Australia. All is good on my iphone but on my home pc and work pc i am getting certificate related errors indicating this maybe an issue at the BT end
Message 6 of 13
Re: security
That'll be an error on BTs end.
They need to renew or correct their SSL certificate
Message 7 of 13
Re: security
This has been fixed by the looks of things as i can now access without any issues
Message 8 of 13
Re: security
I'm now able to get into my E-Mail
Message 9 of 13
Re: security
Must have been sorted as can now get in, would be helpful to know why this happens though?  thanks jules
Message 10 of 13
Re: security
As @verkosh said, BT inadvertently allowed the SSL certificate to expire.
