Message 1 of 4
six digit e mail verification
Started for me today i get the number and can access my e mail but when i leave the page i have to repeat the process every time i return. I have lap top using W11. I  tried  speaking with BT customer care without any joy and i then tried co pilot which also failed to fix............any help apricated as  its now winding me up. !
PS I did not ask for this two part verification but was informed by customer care that  its being implemented for all BT Broadband users is anyone else experiencing my above problem. ?
3 REPLIES 3
Message 2 of 4
Re: six digit e mail verification
There are numerous posts like yours. BT has implemented 2 step authentication and it cannot be changed or deleted.  If you want to avoid then use an email app not BT
Message 3 of 4
OK could you direct me to which area of the forum holds the numerous posts so i can see if anyone has the same problem as myself and has found a fix.
Message 4 of 4
There is no fix. 2FA is now mandatory, however, as @imjolly has already said, it can simply be avoided by not using webmail and using a mail client such as the free Thunderbird
