Message 1 of 6
subject line missing from email
Switched Probook on this morning, went to send a BT email but the subject line is missing.
Can't find it anywhere
Any clues?
5 REPLIES 5
Message 2 of 6
Re: subject line missing from email
Follow up to this.
I use Opera browser, if i reset browser subject line re-appears, switching off some of Opera parameters after that subject line disapears again, not sure which one, Opera should not affect my BT email i would have thought.
Any thoughts?
Message 3 of 6
@MRANGRY46
Let's assume you've deleted all your BT cookies so there's nothing old and in the way to cause this problem.
You might have to consider downloading a different browser to see if the problem lies with Opera. I don't like suggesting people move out of their comfort zone but it's the only one of the factors (or variables) that you can control.
Message 4 of 6
It is fine on Chrome.
What i have found is the Adblock+ seems to be causing the problem, switch it off and the subject line comes back, switch it back on and the subject line disappears.
This is a brand new instal on a new laptop.
Message 5 of 6
Have a look at this in case it is blocking something from displaying.
How can I see what AdBlock is blocking, hiding, and allowlisting? – AdBlock (getadblock.com)
Message 6 of 6
Thanks for that.
I am using Opera browser, however i did find BT entered three times in Adblock plus my filters, i did not put them there, cleared these down now BT email seems to be working correctly.
