Message 1 of 6
0800 Calls
Hi
I have recently moved to Pay as You Go for my landline number as I normally only use it for incoming calls
I am unable to find out if 0800 calls are chargeable I have checked the BT website but can not find the information
I might and that I am a BT customer and have Full Fibre to the house and my landline number is digital
Would welcome any answers
John
5 REPLIES 5
Message 2 of 6
Re: 0800 Calls
0800 calls are free.
https://www.gov.uk/call-charges
Message 3 of 6
Re: 0800 Calls
Hi Thanks for that info
But I noticed that it is a Gov.UK information link
It also says "You may get free calls to some numbers as part of your call package. Check with your phone provider"
Does BT have a similar link?
I have checked BT Phone Tariff Residential but I cant find anything there regarding Free Calls
John
Message 4 of 6
Re: 0800 Calls
ALL 0800 numbers are free full stop.
Message 5 of 6
Re: 0800 Calls
Agreed
But are There any other Free Calls?
John
Message 6 of 6
Re: 0800 Calls
You don't have a call package if you are Pay as you go.
0808 and 999 are free.
