Message 1 of 5
1571 DV
I have an elderly friend, well into her 90's and a few months ago I assume she was switched to DV.  I noticed each time I called her after this time it picked up on the 1571 messaging service after 30 seconds of the phone ringing but she had no idea what this was.  I explained to her she needed to dial 1571 to listen to any messages but she can't grasp what I have been saying. When I see her (weekly) I check her phone and on one occasion just a few weeks ago she had 12 messages left and one was quite important from her GP instructing her to stop taking a certain medication. I have tried to disable this answering system but failed.  She is not online so it is impossible to do that way.  She is confused due to her advancing years and I would just like to get it off her phone but I cannot find a way.  Can anyone help please
4 REPLIES 4
Message 2 of 5
Re: 1571 DV
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
Try this
Message 3 of 5
Re: 1571 DV
thank you for taking the time to post the link.  I will look at that later today
Message 4 of 5
Re: 1571 DV
Just call BT Customer Service on 150 and ask them to disable Voicemail (I can verify that this works). Incoming calls will then ring for about two minutes/forty rings before disconnecting if unanswered.
Message 5 of 5
Re: 1571 DV
thank you!
