Message 1 of 5
0844 numbers
Hi
I need to ring a 0844 number can anyone help me will it cost a fortune from my BT landline
many thanks Julie
4 REPLIES 4
Message 2 of 5
Re: 0844 numbers
Message 3 of 5
Re: 0844 numbers
Try having a look at the web site "Saynoto0870.com". They list "normal" phone numbers for companies that use 08 numbers. The normal numbers will be part of your calling plan instead of the very high cost of calling 0844/0870 numbers.
Message 4 of 5
Re: 0844 numbers
Thank you for your help
Message 5 of 5
Re: 0844 numbers
Sometimes there is an alternative for if calling from abroad. That will be a standard landline number. Worth a look for one but of the company is determined to fleece customers they might not offer a ‘from abroad’ number.
