Message 1 of 5
digital voice
Hi
Have digital voice but use my current cordless phone by it being plugged into the back of my smart hub 2, I need to know how to pick up any voice mail messages and will I be charged for them.
I have an answer machine on my current panasonic cordless phone if that is turned on should that not record any messages left please?  Thanks Jules
4 REPLIES 4
Message 2 of 5
Re: digital voice
Message 3 of 5
Re: digital voice
this has been covered already using search
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-How-to-disable-voicemail-func...
turn off DV voicemail and let panasonic pick up calls just as before
Message 4 of 5
Re: digital voice
Voicemail  is free on Digital Voice. Dial 1571 to retrieve messages, or disable the service if you wish to use your answering machine.
Message 5 of 5
Re: digital voice
Thank you
