Message 1 of 2
Access of bt mobile voicemail from Australia
Hi Folks
              Currently in Australia and I am unable to access my bt mobile voicemail. I have read some of the suggestions and setting of a pin before leaving the UK and I must admit I was unaware this had to be carried out.
When I access the voicemail from Australia all I receive is an engaged tone, is this correct? no greeting or opportunity to enter a pin?
Any advice would be greatly appreciated
1 REPLY 1
Message 2 of 2
Re: Access of bt mobile voicemail from Australia
@tommymcg
Have a read of these:
https://community.bt.com/t5/Home-phone-including-Digital/Set-up-my-voice-mail-from-abroad/td-p/22881...
https://community.bt.com/t5/Home-phone-including-Digital/Voicemails-while-on-holiday-abroad/td-p/244...
https://www.bt.com/help/landline/using-bt-answer-1571-voicemail
https://www.bt.com/help/landline/all-about-voicemail-for-digital-voice-
Google is your friend, all of this information is easily accessible on a search, or use the search function on this forum.
To be honest if you are going away, in the future, you might be better off just leaving a voice message telling folks to contact you on an email address, just use a throwaway email address you can access on your phone.
