Message 1 of 7
Adapter for existing phone to new fibre optic hub
Hi is there a adapter available so i can use existing phone with the new fibre optic hub , the connection are more square than the slim one on hub
6 REPLIES 6
Message 2 of 7
Re: Adapter for existing phone to new fibre optic hub
The plug on your existing phone fits the green socket at the rear of the hub.
Message 3 of 7
It doesn't fit wrong shape
Message 4 of 7
Where does your phone plug into currently? The standard telephone socket is a 431A the same as the green socket at the rear of the hub. If for some reason your phone has a non-standard RJ11 plug, you can use an RJ11 to 431Adapter.
RJ11RJ11RJ11 431A AdapterRJ11 431A Adapter431A431A
Message 5 of 7
Thanks for the information,  the box i have was a bt broadband one ,it had 2 sockets one for landline one broadband which i cant use any more as its obsolete now that ive got fibre optic .
I really didnt want to get a new phone as ive only had this one a couple of years .
Thanks again
Message 6 of 7
Exactly, the socket for broadband would be Rj11 and for the phone 431A . The phone socket at the rear of the hub is a 431A the same as the phone socket on the 'box'.
I don't understand why your phone has an Rj11 plug.
Message 7 of 7
You should have been offered 2 free Digital Voice cordless handsets when you moved to DV in any case.
