Message 1 of 5
Unlimited Minutes
I'm going in hospital and need to know if my partner can call my mobile from the home landline using the Unlimited Minutes even though it's not a BT plan. Rather urgent. Thanks very much.
4 REPLIES 4
Message 2 of 5
Re: Unlimited Minutes
Yes, calls to any mobile are included.
Message 3 of 5
@Attheend What do you mean by “Unlimited Minutes even though it's not a BT plan”
Message 4 of 5
I meant if the mobile is not on a BT plan but was through another company. Sorry about that.
Message 5 of 5
I had figured that 😀
