Message 1 of 3
BT Advanced Digital Home phone
There does not appear to be brackets available when entering contact names. I want them to differentiate between land lines and mobiles in the contact name. Can they be found
2 REPLIES 2
Message 2 of 3
Re: BT Advanced Digital Home phone
can you just not add home number and mobile number in same contact and when you select the contact you get a choice of number to call - home or mobile
Message 3 of 3
Thanks - Yes I can.
Still struggling with how to use contacts and phone generally as the guide you get is so unhelpful.
Like most things now the people who write guides assume the user already knows the device
