Message 1 of 6
BT Aura 1500 handsets
Getting full fibre in a few weeks and now wondering if it's digital voice system will play nice with my old BT Aura 1500's (1 base station, plus 2 other singles).  I'd rather continue to use them, with it's own answer machine, than the digital voice phone being sent.  Do I just plug the base station into the green socket, with nothing else to do?
thanks.
5 REPLIES 5
Message 2 of 6
Re: BT Aura 1500 handsets
Message 3 of 6
@joepineapples
Yes, but you will need to increase the number of rings on 1571, otherwise it will answer the call before your answer machine.
Message 4 of 6
Thanks Keith.  Where would I change that setting from?.
Message 5 of 6
Sorry, I am not sure. It may be an option on the 1571 menu.
Message 6 of 6
you can change the number of rings before 1571 answers in MYBT under digital voice
