Message 1 of 7
BT BBU for Digital voice over copper smart hub 2
please can anyone answer this what BBU ( batteries backup unit is the correct one for my BT smart hub 2
witch is the right one
also dose this also let you brows the internet
i live in a place with no mobile so i have to do wifi calling so need the router to work
i have at least 1 power cut a month most are only 60 secs to 10 mins others can be for a hr or so
have any of you actually had real world experiance of when you have a power cut still been able to brows the internet through a BT smart hub2
& whitch one of these is the corect one for me
my internet is over copper cable
Cyberpower Power Supply Battery Back-Up For BT Digital Voice Service (
Cyberpower Power Supply Battery Back-Up For BT Digital Voice Service (Non FTTP) (New)
Cyberpower Power Supply Battery Back-Up For BT Digital Voice Service (Non FTTP) (Renewed)
yours really hopefully
6 REPLIES 6
Message 2 of 7
Re: BT BBU for Digital voice over copper smart hub 2
Message 3 of 7
You may want to consider the better BBU ( the FTTP one ) , if on copper , the BBU only needs to power the router ( presumably whatever device you use already has a battery, like IPad or laptop) , if you were on FTTP the BBU needs to power the router and the ONT , so although you don’t have an ONT now , because you are not on FTTP , it would future proof yourself for when you do get FTTP .
As far as real world experience, the power cut ‘panic’ is so overblown ( IMHO ) that the chances of those that claim they needed a BBU , and got one , and then have actually had to use it in a real world situation ( during a power outage ) will be small , so getting that small group ( BBU and genuinely needed it as they had a power cut ) to comment on here will be unlikely, but you never know, some may comment but wether they genuinely had a real world outage may be up for debate.
As  the BBU takes over the power supply of the router if the mains fail  , for as long as the battery lasts in the BBU , the broadband service will be identical ( the router doesn’t care ) with the small chance that as the mains power fails and the BBU kicks in , the router may briefly drop out and have to re sync (  a small break in service ) the way these work is your router is connected to the BBU , the BBU connected to the mains , as the mains fail the BBU takes over .
Message 4 of 7
I wouldn't use either, get a third party UPS.
Message 5 of 7
any recommendations link to product would be nice
SH2  Draws max 14.7 Watts
I will need something that lasts a couple of hrs
the BT BBU allegedly can go for 2 hrs
would like something that will last the same duration
Message 6 of 7
unfortunately, I live in a world of frequent power cuts on a Scottish island.
I live in the middle of a field on the side of a hill over 100m from the joint box on the road & half a mile at least to the cabinet.
& no mobile coverage.
so there is no way that BT is going to make me FTTP ever, as the cost of trenching & fibre cable would be too costly.
Message 7 of 7
Have a look at CyberPower BR700ELCD
