Message 1 of 3
BT Decor 2200 v2 - Message light continually flashing
I have 3 BT Decor 2200 v2 phones in use. All are VOIP using BT high speed broadband.  On all 3 the 1571 message light has recently started to flash continuously even though there are no voicemail messages waiting.   All has been ok for the last 7 months, but this problem has occurred.  Any ideas of how to stop the lights flashing when there are no messages waiting?  Thanks,
2 REPLIES 2
Message 2 of 3
Re: BT Decor 2200 v2 - Message light continually flashing
I would try leaving yourself a new message and then deleting it, should hopefully clear it up!
Message 3 of 3
Thanks very much for your prompt response. It worked!
