Message 1 of 6
BT Premium Trio Phone 1 has white screen
Hi we have the trio Premium BT phones with nuisance blocked, however one handset for some reason is only showing a white blank screen, you can still dial numbers however you cannot see anything on its screen at all.
So far I have switched off the main base for a few minutes, also removed the handset batteries for a few minutes and this doe not work, also tried different rechargeable batteries and still a blank white screen.
After trying everything I am at a loss of what has happened to the handset, can anyone advise on what to try next
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: BT Premium Trio Phone 1 has white screen
Sounds like it's faulty but might be worth a factory reset.  Use one of the working phones to guide you through the button presses to get to the reset option.
Message 3 of 6
If I reset it I take it I'll loose all numbers in the phone book
Anonymous
Not applicable
Message 4 of 6
Contacts are stored on the base station so resetting the handset should have no impact. But as you'll be working blind, I guess there's the risk of an error. But if you have a phone in each hand & mirror what you do, you should be OK.
Message 5 of 6
Managed to reset the handset unfortunately after it switched off and back on and a beep then screen is still white, thanks for your advice and help though much appreciated 👍🏻
Anonymous
Not applicable
Message 6 of 6
A replacement from Ebay is probably the best bet.
