Message 1 of 6
BT Premium phone display
Hello,
I have just purchased a BT Premium Trio.
It has a peculiar quirk -- when I key in a number the display has a very large font size, only about five digits fill width of screen.  Is this how it is meant to be ?  I want to change it to use a more sensible font size, but can't find anything on the menues for this.  Can you help?
Thanks,  Ken.
5 REPLIES 5
Message 2 of 6
Re: BT Premium phone display
Go into Accessibility menu and you should be able to adjust it there.
Message 3 of 6
I cannot find the Accessibility menu -- can you help?
Message 4 of 6
Open Menu, navigate three steps to the right, then Select.
Message 5 of 6
When I open Menu, I cannot navigate left or right, only up and down. I navigate down to Settings and select it, but cannot find Accessibility there.
Message 6 of 6
Apologies, I misunderstood which phone you were referring to. If it's the BT 8600 you could try removing the batteries for a short while and/or a factory reset. Otherwise the helpline on 0800 145 6789 should be able to advise.
