Message 1 of 5
BT Response 75+ along with Call Blocking/Guardian
Hello,
I was wondering if anyone knows what would happen if I connected a BT Response 75+ to a BT 4600? Since this phone has call blocking, would the answering machine still register it as a new call or would it pick up only once the call comes on the handset?
Many thanks
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: BT Response 75+ along with Call Blocking/Guardian
Not sure why you'd want to connect an answering machine to a phone that has one already built in? What exactly are you trying to achieve?
Message 3 of 5
I’m using another answering machine for extra capacity, so I can just switch one off then when the memory is full on that I can switch on the other. I’m trying to stop nuisance calls from coming through, however the Response will pick it up after 9 rings, will it still be registered as the phone ringing once I’ve picked up the phone to go to the accept/block/answer phone so it will intercept and head to the answering machine or will it pick up when it comes through as “Announced call”?
Anonymous
Not applicable
Message 4 of 5
If you have blocking turned on then the call will be answered by the 4600 almost immediately, certainly long before the Response kicks in. As the answering facility in the 4600 is intrinsic to the announce feature, I doubt it would work if its own answering machine was turned off. It certainly wouldn't use the Response.
Anonymous
Not applicable
Message 5 of 5
I've just tested with my 8500 & even with the answer turned off, announced calls are still sent to answer.
