Message 1 of 4
BT Wholehome and Digital Voice Adapter
Hello. I have BT Wholehome which I purchased independently of my BT router as I couldn't get additional discs to extend my network from BT (I tried but was told I couldn't have them on my contract) when  I needed the additional coverage. I have used the BT Wholehome as my only WiFi network switching off the BT router WiFi.
I now have my new router and will switching over to the digital voice network. Will I be able to switch off the BT SmartHub Wifi and use the BT Wholehome network to register my Digital Voice Adapter against my service?
3 REPLIES 3
Message 2 of 4
Re: BT Wholehome and Digital Voice Adapter
@Fox1
Welcome to this user forum for BT Retail phone and broadband customers.
The Digital Voice Adapter does not use Wi-Fi, but it links to the Smart Hub 2 using DECT. This has been discussed many times on this forum.
You can continue to use the Whole Home System, as switching off Wi-Fi on the home hub will not affect your phone service.
Message 3 of 4
Thank you. I had a hunt around but hadn't come across the answer, apologies. Have now plugged in new router, and continuing to setup.
Message 4 of 4
You didn't hunt very far, its all in the FAQ sticky at the top of the board.
