Message 1 of 5
BT digital voice adapter
Old telephone with PSTN connector does not ring on the adapter but works ok  when plugged into the SH2. Also connected phone via a adsl filter thus providing a bell cct works ok. Either the adapter is faulty or never designed with the bell cct. I have just bought it from BT shop and wonder if I need to return it as faulty
4 REPLIES 4
Message 2 of 5
Re: BT digital voice adapter
Never designed for the old bell circuit, not faulty. A replacement will be exactly the same.
Message 3 of 5
@RodF46 - Does it ring with a microfilter plugged into the Digital Voice adaptor (and phone into the microfilter)?
Message 4 of 5
@RodF46 Said it did in message 1
Message 5 of 5
Yes it does
