Message 1 of 3
Pairing a Digital Voice Adapter to the new BT Home Hub
Hi all
Apologies if you've heard this a million times:
I've set up the new Hub and gone through the process to pair it to my Digital Voice Adapter. The instructions say that a green light will flash intermittently until the devices are paired, after which I should get a solid green light on the Adapter.
I'm still getting a flashing green light.
The Hub seems fine - the internet's working fine.
Will the two devices automatically pair up tomorrow when BT switches the service on, do you think?
Thanks,
Rob
2 REPLIES 2
Message 2 of 3
Re: Pairing a Digital Voice Adapter to the new BT Home Hub
Message 3 of 3
the dv service need to be live before you can pair the devices so try when DV active
