Message 1 of 4
BT landline and Virgin cable broadband
I have a BT landline but because the copper cabling in my street is so poor the max BT broadband speed (FTTC) BT quote for me is 16Mb. I therefore have Virgin Media for my broadband. Unfortunately the FTTP rollout in my area stopped 300 yards away and the engineers have all departed so it looks unlikely we will get Openreach FTTP anytime soon. This means my street is stuck with Virgin for broadband.  When the digital phone rollout arrives will I still be able to use BT for my "landline" phone via some sort of adaptor or digital phone? I am reluctant to move my "landline" to Virgin as I do no want to lose the phone number I have had for 45 years.
3 REPLIES 3
Message 2 of 4
Re: BT landline and Virgin cable broadband
Hi @Fossil   I moved my BT home telephone number of 40 years to a VOIP provider. So I can move broadband provider anytime without the risk of losing it. Just Google home telephone voip uk. It was very easy ,and they transferred my number without a hitch. They will guide you if this is new to you. I even kept my BT line while I tested it, you are given a temporary 05 number until you move the BT number which will trigger the BT cancellation.
Message 3 of 4
You can't have BT Digital Voice without some form of BT broadband.
Message 4 of 4
If you basically have standalone telephony from BT and your broadband if from Virgin (ignoring for now why you don’t get telephony from VM and save some cash ,then you are basically back of the queue for BTDV , eventually yourPSTN phone will be converted to IP, there are two methods the chances are the broadband connection will be in the exchange so you will notice no difference, apart from of you currently can call local calls without the STD code you will have to start doing that, if you have two broadbands one from BT and one from VM then your phone will connect to the router
