Message 1 of 4
BT4600 Second Handset Not working as a single handset
Hi, I bought a BT4600 handset on Ebay and it turns out it is the second handset of the twin set. Have recently upgraded our router, but get the message "Please Check Line Cord" when I have plugged in the handset. We are using the same cord as the old phone which was a bit broken, but I am pretty sure it got a phone signal. Can anyone tell me if the second handset of the twin can be used as a standalone unit? Otherwise my issue is perhaps with VOIP not working with this handset. Cheers,
Tags (1)
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: BT4600 Second Handset Not working as a single handset
Message 3 of 4
Thanks so much I will give getting a new cable a go (couldn't find this on search so you are fab).
Message 4 of 4
Bought a new cable and it worked, thanks 🙂
