Message 1 of 4
BT8600 remote access to voicemail
I have set up a PIN for remote access to a BT8600 voicemail and information on the internet indicates that the way to access voicemail messages from a remote phone  is to dial the BT8600 number and wait for the voicemail greeting to start. Then to press the * key to interrupt and enter in the PIN code, and follow the voice prompts to listen to, save or delete the voicemail message. the greeting.
However, when I press the * key (or the hash (#) key) at the greeting, it does nothing - the greeting just continues. Any advice would be welcomed.
3 REPLIES 3
Message 2 of 4
Re: BT8600 remote access to voicemail
Hi @bratman91
Thanks for coming to our community.
I'm sorry you are having trouble with this, I'd recommend speaking to our technical team so they can look into this for you.
Lesley
Message 3 of 4
@Lesley_W  Thank you for that advice - I shall contact the technical gurus.
Message 4 of 4
Hope you get sorted @bratman91
Feel free to pop back with an update.
Lesley
