Message 191 of 282
Re: Call Protect - last call number not showing
Thanks for coming back to me @swatty and letting me know.
I have sent you a private message for some details 🙂
Leanne.
Message 192 of 282
Mine always rings. And like you they don't always showup  on call protect calls received log.
Message 193 of 282
Exactly Pete.
Message 194 of 282
Still got the faulty line and one of the numbers that didn't show on Call Protect showed on both yesterday, so that kills off the line fault theory.
totally off topic :  The line not fixed yet was due to multiple system(or user) issues in BT , for some reason it wouldn't log the fault correctly for the call handler, so no engineer assigned and it closed the fault.  Took them about 30 minutes to get it booked today.
Anonymous
Not applicable
Message 195 of 282
Had another scam call just now,
02840520874
Received today 25 Sept at 14:02
Tried to use Call Protect, and as usual, BT said " Call unrecognisable" so can't be saved to my block list.
I googled this number
This number, primarily associated with insulation scam    is a landline operated by BT located in Banbridge Northern Ireland.
The overall user rating for this number is Negative . The number 028 4052 0874 has been looked up 1,353 times, leading to 30 user comments that have helped form a clearer picture of the caller's intent.
So, Leanne, can you see how call protect is not doing its job.
Message 196 of 282
Hi @Anonymous
Thanks very much for supplying those extra details, I have shared these with the team now.
Leanne.
Message 197 of 282
Same is happening to me since a few months now.
What is the solution?
Message 198 of 282
Hi @thomas_e
Thanks for coming here.
I've sent you a private message on here for some details.
Leanne.
Message 199 of 282
No solution offered by BT yet, been going on for over 8 months.
I phoned my landline yesterday and could see it on Caller ID , but not on Call Protect.
Phoned again today and could see it on both
Message 200 of 282
Did you get a refund for the service not working?
