Message 1 of 12
Caller ring
No sound on digital phone including caller ring and touch tone although everything set up correct
11 REPLIES 11
Message 2 of 12
Re: Caller ring
That's an issue with the phone you're using...you'll need to add more info about the phone and model number etc if you want someone to offer some advice
Message 3 of 12
Re: Caller ring
All I can see on the phone is HD VOICE, I have two handsets, the other one works fine.
Message 4 of 12
Re: Caller ring
Making a bit of a guess here but if you press and hold the * key that might turn the ringer back on?
Message 5 of 12
Re: Caller ring
Thx tried it , it rang once and then nothing since
Message 6 of 12
Re: Caller ring
Hi @phil4227
Which model handset do you have? Have you tried switching it off at the socket, then switching it back on again? It may also be worth restarting your router to see if that helps.
Chris
Message 7 of 12
Re: Caller ring
Will try tomorrow thx
Message 8 of 12
Re: Caller ring
Morning @phil4227
Please pop back and let us know how you get on 🙂
Leanne.
Message 9 of 12
Re: Caller ring
Ringer and touch tone still not working
Message 10 of 12
Re: Caller ring
Hi @phil4227
Thanks for trying.
In this case, please get in touch with our Broadband tech guides, they can get the digital phone ringer looked into for you.
Let me know how you get on 🙂
Leanne.
