Message 11 of 26
Re: Can Digital Voice work with this wiring?
We've discussed this before or at least I have asked that question but BT seem to insist that I have FTTP in order to have Digital Voice. I started getting copious emails from both BT and Oprenreach from about March onwards and at regular intervals saying 'we are upgrading you, at no extra cost to DV and Essentials FTTP' and giving me an installation date. Each time on the Openreach email I reject their offer as they give a link so to doe and they say OK, you'll remain on your existing service ( ADSL in my case). I shall keep on doing this until they won't allow me to do that. Why won't they give me DV over my ADSL connection?
Message 12 of 26
DV is totally agnostic to how your broadband is delivered. It is just another IP stream, no different to accessing a website.
Message 13 of 26
@HHGTTG
Why not DV over ADSL? I’m thinking that Openreach may be wanting to also migrate broadband services off exchange based (ADSL) kit as part of exchange closures perhaps?
I know that in some areas people who have no broadband services at all - just a POTS - are being migrated to DV with essentially an exchange based ATA cut over to replace the PSTN termination. No visits or hubs needed. And still ‘exchange’ powered.
But at the end of the day it’s going to happen. If you’ve got Broadband and Phone over the Openreach access network you’re going to lose that ‘exchange’ powered landline.
Message 14 of 26
@HHGTTG
If you are in a Openreach Full Fibre (FTTP) priority area then the copper based services are being withdrawn.
More areas are now becoming an Openreach Full Fibre (FTTP) priority area and now this is also aligning and being combined with Digital Voice migration too.
Hence the required move to Openreach FTTP is combined with Digital Voice and vice versa.
You can check if you are in a Openreach Full Fibre (FTTP) priority area by going to https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
If you post the results (minus your address) but also include the footnotes it will help state if your in a Openreach Full Fibre (FTTP) priority area or not.
https://landlinesgo.digital/checkmyline also helps explain what the results means
Message 15 of 26
My summary is that my mother is in a fibre-first area with WLR being withdrawn. Digital Voice is mandatory for landlines. In theory she'll get up to 1 Gb/s through FTTP.
It also notes: "Residential OH Feed with no anticipated issues."
So, I think that means they'll run the fibre from the pole ("overhead"), and are assuming that they can follow the existing routing for the analogue wiring. That's not true as the current routing now runs under tiles that were added after the line would first have been put in place many years ago. It's not readily accessible.
Should I flag that in advance to Openreach (i.e. correct their "no anticipated issues" line)?
Also, how amenable is their engineer likely to be to customising the routing? Drilling through the wall at the location of the cable end-point on the property won't work. There is no power socket anywhere near, and running a power extension cannot be done easily without creating an untidy trip hazard for my mother.
My preference would be to run the fibre cable down the outside of the property, then through the wall of the foundations into the property, under the floorboards, and up through the floorboards into the other side of the entry room close to the power socket. The house is split level, so unusually, I can easily crawl through the foundations under the floorboards to organise cabling. That is how I fitted the long run of ethernet cabling that is represented in the wiring diagrams I posted. I would be at the property for the engineer's visit to do that. I imagine that would be the quickest way to do the installation, and also the cleanest.
Message 16 of 26
Thanks @Anonymous. That's a helpful recommendation. I'll probably look into getting something like that.
Message 17 of 26
@pddco Thanks for the reply. Yes, in my naivety when I originally laid that cable back around 2016, I didn't actually know that the bell wire carried power, let alone that it was of a relatively significant level. Rather, I was just approaching it all as a wiring puzzle! I only learned yesterday through Googling - and as you have kindly pointed out - that people advise against running the ring signal bundled with the ethernet signal into a single cable in the way that I have done. Still, it seems to have worked ok, albeit for the relatively light usage it has typically had.
I will see if the old bell coils do spring back to life after the FTTP installation, however I am doubtful. They are quite hefty mechnical things - not far off being a domestic equivalent of Big Ben - so I can't imagine they would get triggered.
Message 18 of 26
@john-tejada
I'm in the same position as your mother in a way. Personally, I can only see Openreach doing the simplest of exterior routing to the CSP terminal. My current old master socket is in my  long hallway just below the hall window overlooking the road. There is a small table here with an ordinary phone on it. There is no power socket below the table but only about 8 feet away down the side of the hallway where there is a wheeled trolley and table lamp etc. I would have to take a coloured extension lead from here back up the hall, past the front door and around a corner to reach the area near the old master socket and where the ONT would most like to be. The extension lead would have to go under the the interior door mat and be secured with a few clips. However, I would not want the Hub to be on the hall table in direct sun where it would bake in the Summer's heat and so I Have a long Ethernet cable available to run back from the Hub to the trolley where the Hub would be situated and also have power available from the mains socket below. A bodge I know but this is the only answer.
Like yourself, there is an alternative position in another room where there is power convenient for me but I cannot imagine OR threading and external fibre cable to that part of the house around  many corners and front door that is at a right angle to the facing wall of the house.
Message 19 of 26
@HHGTTG
Yes, that sounds tricky. There will surely be many customers in a similar postion. It's a little frustrating.
On the CSP point, I had been wondering whether they would fit a CSP at my mother's house. I have read that they don't always do that, and instead sometimes go straight through the wall, then strip back the external cable. I think I'd prefer a CSP for neatness of wiring.
On your particular wiring dilemma, I did also read anecdotes on some forum posts about engineers sometimes being ok to run the internal fibre cable for up to 10m. I am guessing that could work for you in that you could run the fibre from the entry point, past the front door (under the mat), and then clipped along the hallway and round the corner to your power socket? Still, it's presumably at the discretion of whoever does the installation.
Part of my thinking is that if I can present the engineer with the quickest plan for what also happens to be the best solution, then he/she might be inclined to go along with it (and then get on their way to the next job as soon as possible).
Message 20 of 26
@john-tejada
I can't imagine OR not fitting an external CSP box as that is where the connection is made to the internal, thinner cable and indeed is spliced there and where a few turn of excess cable is put.
