Message 1 of 2
Can I used my DECT phones downstairs into router with a BT Digital phone upstairs?
Hello,
I've successfully plugged my cordless DECT panasonic phones into my router and it's working well.
I have an ancient corded phone upstairs that would work with the suggested digital adapter, but I'm wondering if i accepted the new Digital Handset instead I could use it congruently with my panasonics, replacing the corded upstairs.
Thanks for any help.
1 REPLY 1
Message 2 of 2
Re: Can I used my DECT phones downstairs into router with a BT Digital phone upstairs?
@betdevonish wrote:
Hello,
Yes, that should work fine.
