Message 11 of 34
Re: Can't access DV 'Call Protect' feature using BT account
I only have one device a laptop, I have contacted BT by online messenger but they are useless dont seem to be able to find out whats wrong. As all other functions work it looks like its a problem with just Call Protect. Nothing happens when I click the 'Manage' tap to go into Call Protect page.  My list is full so wanted to delete a few older numbers to add new ones. Looks like I will have to delete one at a time on the phone until its fixed. I note others have same problem.
Message 12 of 34
I can't see settings in  Account Holder vs Account Manager
Please help.
Message 13 of 34
Hi @Brian5856
Thanks for coming back to us,
If the settings are not showing for you, please get in touch with our technical support team, so they can check this for you.
Let us know how you get on 🙂
Leanne.
Message 14 of 34
Moderator.  I have since tried to access my call protect on another computor, and it the same problem, no response when I click on the go to tap for call protect, so it must be a BT issue.
Message 15 of 34
Hi @7815678
Thanks for checking.
In this case, please call us and the team can get your Call Protect looked into and help you get this sorted 🙂
Leanne.
Message 16 of 34
I have just spoken to a BT advisor but he could not find the problem,  nothing wrong with may account settings, so  looks like its a computor fault at BT's end which hopefully will get resolved with next update. I asked him to refer the matter to the IT dept.
Message 17 of 34
Hi @7815678
Thanks for coming back to me and for reporting this to our BT guides.
Hopefully this is sorted soon for you.
Leanne.
Message 18 of 34
I have exactly the same problem.  You press "Manage" and nothing happens.
Message 19 of 34
I've been helped by a BT adviser on My BT Chat. He has tried all sorts of things, the last being to remove call protect from my package and then reinstall it. He has asked me to wait and check within 24 hrs to see if it cures the problem.
I'll report back the outcome.
Message 20 of 34
Further to my last. Using BT Chat I have booked an engineer to investigate the MY BT website problem on Wednesday.
