Message 1 of 34
Can't access DV 'Call Protect' feature using BT account
Hi,
About 6 months ago BT upgraded me to Digital Voice and gave me the BT Advanced Digital Phone. Unfortunately, I've managed to inadvertantly block a friend's phone number and want to unblock it. I've logged into my BT account and gone the options to manage Digital Voice features, specifically 'Call Protect', so I can remove the number from the block list. However, I am unable to access it or any of the Digital Voice features as they all say:
'Please contact your account holder to manage this feature'
I am the account holder!
At the moment, I've had to switch off 'Call Protect' (using 1572 from the phone) to disable call blocking so my friend can ring me without getting the awful BT blocked call message! And, of course, now I can't block any real scam calls.
Any suggestions as to what I might be doing wrong or why BT thinks I'm not the account holder?
Thanks in advance.
Vinny
33 REPLIES 33
Message 2 of 34
Re: Can't access DV 'Call Protect' feature using BT account
Message 3 of 34
Hi @Vinny_L,
Thanks for taking the time to post up on the Community.
It sounds like your online account role is what we call an Account Manager. It lets you view bills but it doesn't give you rights to make a lot of changes. This is usually set up for someone who is helping someone else with their bills.
You will need an Account Holder role. You can find out more here: Account Holder vs Account Manager
Scroll down to the part that says "I should be the Account holder but I'm currently listed as an Account manager. How can I change this?". That should show you how you can become the Account Holder for your online bills.
Let me know how you get on with that, please.
DanielS
Message 4 of 34
Hi @DanielS
Thanks for the suggestion.
I've only ever had a BT account for myself, so a bit confused why BT would think I'm managing it for someone else.  Anyway, I made the change and my account details now show me as Account Holder. However, the options to manage the DV features are still saying 'Please contact your account holder to manage this feature' .
Still a bit confused 😕.
Vinny
Message 5 of 34
Hi @Vinny_L thanks for doing that and I'm sorry it's still not working. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to help.
Neil
Message 6 of 34
Hi @NeilO ,
I checked my BT account again this morning and, miraculously, I can now access the options to manage DV features. It evidently takes a bit of time for some changes to take effect 🙄.
Thanks all for the help .
Vinny
Message 7 of 34
@Vinny_L no worries, I'm glad you got sorted.
neil
Message 8 of 34
I have the same problem. I am the Account Holder but I don't follow your instructions.
Message 9 of 34
I too cant access Call Protect on my laptop, when I click onto go to tab nothing happens, have tried messaging BT help line but they are useless and did not seem to understand what the problem is. Looks like a problem with the web site, hopefully it may clear after system updates.
Message 10 of 34
Hi @Brian5856 and @7815678
If you're getting this problem on more than one device or browser, it may be worth calling into our technical support team, so they can check everything from our side for you.
Chris
