Message 11 of 12
Re: Can’t add Caller ID
Thanks for the explanation.  I’ll take your advice and see what happens.
Message 12 of 12
Called BT today and was advised that it wouldn’t allow me to add the service via MyBT because they are in the process of transferring across to EE.  Also, now need to switch to Digital Voice with EE.  Time will tell if it works ok when it switches over tomorrow.
