Message 11 of 12
Re: Cannot Hear Caller
It might not be relevant to you, but this may help someone with a similar problem.  A few years back when still on pstn we had the same issue - but a different resolution.  In our case it turned out one of the corded extension handsets was faulty, and was bizarrely causing problems with all the handsets - we know it was the handset because it caused the same problem plugged into the main phone socket. Discarded that handset and everything else worked perfectly!
Message 12 of 12
Thank you for sharing @Chookgate
I am sure this will be helpful for other customers 🙂
Have a great weekend.
Leanne.
