Message 1 of 8
Can’t clear Voicemail green light since latest change to DV
I have the BT Alexa DV phone, plus four DECT phones through a DV adapter.
I got the update OK, heard about it on a voicemail message on the DV phone, cleared all new messages, took the 5-button option to access the older voicemail system, and cleared that also.
But the green Voicemail light is staying on.
I repeated the above, old and new voicemail, to double-check both are cleared, and they are.
How do I get this green light off?
On a related note, the DECT phones are giving the voicemail tone, but the same thing is reported; no voicemail in either the new nor the old voicemail box. How do I get these off this phantom voicemail also?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
7 REPLIES 7
Message 2 of 8
Re: Can’t clear Voicemail green light since latest change to DV
Message 3 of 8
Nope, nothing there about it 😢 You need better AI…
Anonymous
Not applicable
Message 4 of 8
As it's flagging by two methods, it must be an error. Give it overnight to clear & if it doesn't, I guess you'll have to call to report it.
Message 5 of 8
Did you manage to get the green light off? The same thing has happened to me since yesterday.  I’ve cleared all  messages from the old and new Voicemail but green light still showing.
Message 6 of 8
Message 7 of 8
Thanks so much for the link to the solution, it actually worked!
Message 8 of 8
Thanks for coming back and letting us know @FionaMc
Glad you got this sorted 🙂
Leanne.
