Message 1 of 6
Compatibility question
Is the EE Home Phone Plus compatible with the BT Home Hub 2 ?
5 REPLIES 5
Message 2 of 6
Re: Compatibility question
Found the answer.
Message 3 of 6
Are you going to keep it to yourself or are you going to share for the benefit of others?
Message 4 of 6
Just for you chief......
Message 5 of 6
Not for me, it's for anyone else with the same query.
Message 6 of 6
Yes I am fully aware of  that.
