Message 1 of 4
Contacts on Hub 2
Recently, I have had MAJOR problems with EE TV, and had to reset my Hub 2. This, of course, wiped off my contacts for DV.
When I tried to import contacts file from my Mac, ( which I have done several times before ), it will not let me, stating " C:\fakepath\ ........
Does anyone know how I can get round this issue?
3 REPLIES 3
Message 2 of 4
Re: Contacts on Hub 2
Message 3 of 4
Try copying the file to another device and see if you can import from that.
Message 4 of 4
Copied to iPad, and then to Hub 2. Success.
Brilliant! Thanks liquorice.
