Message 1 of 2
Crackly line, again
Hello,
I have a crackly landline, once again. This seems to occurs every few years. It has been happening for about 8-10 years now.
The fault is usually a joint up the telegraph pole.
Please help repair it, once and for all.
Thank you, Steven
1 REPLY 1
Message 2 of 2
Re: Crackly line, again
3 times in 9 years isn't bad going really, however the network is owned by Openreach, so they will need called by your ISP to report this.
I have the same issue, I have an underground feed and every 2 years or so the joint needs replaced, BB goes flakey so a quick call and it's replaced before a total loss of broadband happens.
