Message 1 of 11
DV phone and 2 factor authentication call back fail
I have  had full fibre from BT for several months, and they moved the phone onto Digital Voice.  I have the Alexa handset ( and BT Dect ansaphone / handsets on the adaptor ).
They all work for making and answering calls from landlines / mobiles.
BUT - the phone DOES NOT RING when receiving a call from a company with 2 factor authorisation - sending a code to the landline to enter to prove identity / security!
Alexa phone immediately shows a missed call on screen and in call list, and if I am quick it seems to say not available?
This happens with Halifax and HMRC so it's not just one company problem.
I noted the HAlifax number appeared to be from a mobile number ( it's all auto ) .
Any ideas /  help?
Yes I can set the company call back number to a mobile and it does work ... but should also work on landline as it used to do!
10 REPLIES 10
Message 2 of 11
Re: DV phone and 2 factor authentication call back fail
Message 3 of 11
So, Nobody has seen this before?
Is it some setting or spam/junk filter on these phones??
Message 4 of 11
Tried a few more companies, including NS&I, and it still occurs.
Phone otherwise makes and receives calls fine.
Message 5 of 11
just a suggestion but the DV has ability for 2 simultaneous connection so have you tried changing calling on phone from multi to single
Message 6 of 11
Thanks, not tried that.
Been on to BT for 45 mins ... may just be something silly like blacklist takes withheld numbers ... even though I can see the numbers on the Alexa DV handset!
Cheers, I'll let you all know!
Message 7 of 11
Ok, back again.
I finally found how to turn off multi call on the DV handset.
No help.
Calls back from e.g. Halifax bank, HMRC etc. for 2 factor authentication do not ring on the DV phone, despite the calling number being displayed IN the calls list!
Halifax also returns a message on screen that there was no answer to their call.
Any one got any ideas?
It's obviously a Digital Voice issue, or my settings in the phone or MyBT account!
Message 8 of 11
hi Jerry Lee - re digital voice & 2 factor authentification call back fail, were you able to sort this out?
Message 9 of 11
Hi there,
I forgot to update this issue, as it was not a frequent need to get a call back to the DV landline!!
So, in short... YES.
After a couple of calls to BT help desk, who were sort of helpful, it came to a simple setting.
In the call protect settings I had blocked unidentified numbers AND foreign calls.
Guess what, Halifax call backs come from France and HMRC via spain ( ir was it NS&I ?)
Anyway BT help checked and confirmed these settings, I removed the number I had found was HMRC and NS&I from my black list, then removed block foreign calls, and Voila! it worked.
Now DO get call backs to the DV landline from HMRC, Halifax building society and NS&I.
Hope that helps people!
Cheers
JL
Message 10 of 11
many thanks from Parmesan1
