Message 1 of 4
Deleting speed dials on the digital voice handset?
I’ve got the standard digital voice handsets but a couple of the speed dial numbers have got corrupted somehow. Does anybody know how to clear them all & start over? I’ve performed a reset on all the handsets & then registered them again with the hub but the speed dials are all still there (along with all the address book entries). I can’t see anything at all in the settings menu about clearing them & it won’t let me overwrite the existing speed dials with new numbers.
Thanks in advance.
3 REPLIES 3
Message 2 of 4
Re: Deleting speed dials on the digital voice handset?
Message 3 of 4
Not sure why this hasn't been answered and you might well have softed out yourself but I'm a BT customer and here's your answer.
Deleting a speed dial entry from a Digital Voice handsett
1 Select the Contacts list, then the right navigation
button.
2 Scroll to the speed dial entry you
want to edit and press Options.
3 Scroll down to Remove and select using the relevant softkey (the keys marked with a dash with two dots above them)
4 Confirm yes or not using the two softkeys (the keys marked with a dash with two dots above them)
Done
Message 4 of 4
@PeterNorfolk
This thread is amost a year old so hopefully the OP has it resolved by now so may not respond but your post may help others.
