Message 11 of 19
Re: Digital Voice in a power cut
In which case you need a corded phone , irrespective of moving to FTTP or DV
Message 12 of 19
could you tell me how to do this please?
Message 13 of 19
How to do what?
Message 14 of 19
Message 15 of 19
I was asking about how to pair my handset to the hub instead of the base station
Message 16 of 19
Could you let me know which handset you are using @fredddd?
Rach
Message 17 of 19
thank you for responding  My current phone is BT 3110 but from my research, it seems that I can't pair this one to my hub or use the green socket in the back of the hub? I am looking at a BT/EE digital voice only phone that can be paired with my hub and will go that route if I have to.
Message 18 of 19
Right, first of all if you wish to continue using your handset with the existing base, simply plug the base into the green socket on the hub.
This thread is about using your phones in a power cut. To do that you need to power your hub (and if you have FTTP, the ONT) by means if a UPS.
If you wish to connect your existing handsets directly to the hub without connecting the base to the hub green socket, re-register the handset from the 3110 base and register it to the hub by pressing the WPS button on the hub and following the instructions on page 37 of the manual linked below.
https://telephonesuk.org.uk/wp-content/uploads/2020/12/BT3110-User-Guide.pdf
Message 19 of 19
many thanks!
