Message 11 of 20
Re: Digital Voice Battery Backup
@dephead2004 Another issue with battery backup is the actual shelf life of the Lithium or Sealed Lead Acid batteries. When the time come when you need backup, you may find that the battery capacity has gone, and you have no backup.
Time to make up a 12V pack of normal alkaline "C"  batteries which have a much longer shelf life, and are easily and cheaply changed.  This can be brought into service should you have a power cut.
Message 12 of 20
@gg30340
I think you'll find  that too many people, who are not well informed, will rely upon and believe coverage maps. It's only after they have purchased the phone that they discover the truth
Message 13 of 20
@Les-Gibson wrote:
@gg30340
... which they will have found out before they try connecting to "wifi calling".
Message 14 of 20
@gg30340
Your point being ?
Message 15 of 20
You stated " In these days of Wi-Fi calling, how many people have turned off the Wi-Fi on their mobiles in order to check that they have a decent enough mobile signal to enable them to make a call if their internet connection failed? not many I would wager".
I posted that I doubt it would be many people who would be unaware whether or not that they had a decent mobile phone signal because they would already know if they had a mobile signal at their home address.  Not least because it is virtually the first thing people check when they get home with their new mobile phone long before they try and connect the phone to their home network and set up "wifi calling" .
Message 16 of 20
That statement is truly worthy of Captain Obvious, the real problem is that many people know that mobile reception is bad where they are so they consult the coverage maps to see which network they should go for only to find that it's all very much of a muchness. What network do those people go for knowing that , do they perhaps not bother at all?
Message 17 of 20
I really can not be bothered with this. You posted one thing and now you are trying to justify it when it has been pointed out there is a hole in what you posted.
Message 18 of 20
Whatever
Message 19 of 20
If you want to use cellular phones as a back up who your supplier is important, I was happily with EE until I suddenly lost all signal, on investigating I found they had removed their local mast.
On talking to their customer services the very helpful lady said she would have to read from her script as no one including her would believe it, it said "It was to enhance customer service" She just gave me as large a goodwill payment as she was allowed to and I switched to O2.
Message 20 of 20
@Bob1001
I can believe it.
I don't know about EE but an agreement was reached last year between O2, three and Vodafone to share their masts so if you get poor reception on one of those networks then it follows that you will get poor reception on them all regardless of what the coverage maps might tell you.
You are not restricted to your own operators masts for emergency calls but the fewer masts there are will obviously restrict availability
