Message 11 of 32
Re: Digital Voice Conversion Problem
No, although I have dial tone on the phone connected to the green socket on my hub, I can neither make or receive calls on it.
If I ring my landline number from my mobile, all that rings is the phone that is still connected to my landline.
Message 12 of 32
@Victor_Delta
It could be that the number is not yet fully ported over. The hub/router where is shows service ready should also show what number it's been allocated. Assuming that number is the one you are expecting?
If it's still not working tomorrow then best give customer service a call as there maybe a number porting issue
Message 13 of 32
The number shown on the hub is my correct number.
Don’t forget the email I received last night said it could take up to 48 hours. So I’ll wait and see what happens and report back on any developments.
Message 14 of 32
You are lucky.
They disconnected my line on 14th of April. Without telling me. An aged person in poor health on the Special Register. I missed a vital telephone call from my doctor as a result.
I have now been without a telephone for FIFTY DAYS. And rely on a VHF radio link to a friend. Should I need paramedic assistance. ' Consumer resolution '.  Pathetic shower.  Tell me they are unable to resolve the problem. And advise me to go to another provider.
I have only been with BT/ Openreach / EE since November 1971
Good luck with your problem
Message 15 of 32
Sorry to hear of your problem - sounds dreadful.
In the past, I've always found an email to the CEO or Chairman's office can help to get things sorted. This is a very useful website and lists Allison Kirkby's email address. I'm sure she'd be interested to hear about your recent experience of her company.
Message 16 of 32
Message 17 of 32
Hi @80internettbhewlett
I'm really sorry to hear that you're having this problem with your landline service. I've sent you a private message to try and get you some help with your service.
Please take a look at your community inbox and get back to me please.
Thank you.
Chris
Message 18 of 32
Returning to the original digital conversion problem...
I phoned BT today and spoke to a helpful 'guide' in Dundee. He scratched his head and did various tests etc eventually concluding that the 'suppliers' (Openreach & BT Wholesale) had signed off the line conversion as completed - when clearly this was not correct.
Anyway he did what he called a 'kick start' and, although he initially thought it had not worked, after a minute or two I received a text and email saying the DV service was ready to use. Sure enough, there was no longer any dial tone on the landline and the phone connected to the router was finally able to make and receive calls.
Success at last, but not without manual intervention.
Message 19 of 32
Thanks for coming back to let us know, @Victor_Delta
I'm glad to hear that it all seems to be working now.
Chris
Message 20 of 32
In terms of the move to digital voice that is usually within the 24hours of the date conversion given to you but may take 48 hours in some cases. Number porting process can be one of the reasons why it's taking longer than 24 hours. Also your hub needs to be pushed a configuration file and configures on backend resources needs to be updated. (This is why a reboot can sometimes speed things up as it triggers that refresh of configuration of the hub )
Is your phone service via Digital Voice working?
The disconnection of the PSTN line is a secondary process. In summary, once moved to Digital Voice you need to connect your phone handset to either the phone port on the back of the supplied smart hub or via a digital voice adapter and this should allow you to make calls and receive calls once the service is ready.
From the customers perspective that is all they need to worry about, as for then decommissioning the PSTN service that's a more manual process but shouldn't need the customer to know or worry about.
I know this thread is marked solved, but it came up when I was searching for the same thing last week and I wanted to add my own experience in case it helps anyone else reading it later.
The bit about the old landline still working is what threw me. In my case the PSTN line stayed live for about four days after Digital Voice went active. I could still make and receive calls on the old handset, which made me think the switch hadn't happened yet. It had. The two just run side by side until Openreach does the exchange work, exactly as described above.
Also worth knowing: "Service Ready" in the hub manager doesn't always mean calls will connect straight away. Mine sat like that for most of a day before the first call actually went through. A reboot seemed to push it along, same as others have found.
So if you're reading this and your old phone still works while the new socket also has a dial tone, that's not a fault. It's just the overlap period.
