Message 11 of 15
Re: Digital Voice HELP Req'd - best use of current equipment / compatability etc.
@gg30340
Sorry I thought that the breadth of knowledge shared on this forum encompassed all of BT's products.
I'll go check out the BT business forum & see if there is a solution to be sourced from their range which can offer compatibility with BT DV + an external antenna connection.
If not then I'll go with the plan detailed in my post to rbz5416 using a wired 2nd WAP + booster.
Message 12 of 15
Digital Voice is a BT residential product. BT business has its own VoIP solutions but not DV.
It is not, of course, necessary to have BT DV at all and use a third party VoIP provider with your third party kit.
Anonymous
Not applicable
Message 13 of 15
@GARRY_AND_SUSIE
I've never had a SH2 so will bow to others knowledge re WiFi channels.
But I'd suggest upgrading the ancient Netgear for something dual band, & preferably a proper WAP/mesh according to your needs rather than doubling up routers.
BT Business doesn't use DV but a completely different cloud phone service. So there won't be a business product to solve your issue.
As for another router with ATA, the Fritzbox routers have inbuilt DECT & analogue ATA similar to the SH2, but no good for DV as previously stated.
Message 14 of 15
@licquorice Thanks, I think I can work with that & set it to 1 or 11 & hope that the SH2 has channel sharing software on board to play nicely with the neighbours routers on 2.4Ghz, if not I'll tun off WiFi all together on the SH2.
Message 15 of 15
@Anonymous
Thanks for the confirmation, I'll not waste any time on the business forum then, & maybe it could still be added to the FAQ before anyone else drags themselves down the same rabbit hole that I did.
If not - I've bolded your reply above & marked it as accepted just in case anyone stumbles this way in the future
Yeah the Netgear is a bit long in the tooth, (a bit like me) & since retiring the Mrs is in house browsing mode so all this may become moot if she decides on a shift of location so I'll hold off buying anything new just yet but I sincerely appreciate the advice.
Thanks must also go to @licquorice  & @gg30340  for their valuable input & info.
This place really is most helpfull to those of us stumbling through something new & BT related.
I helped out driving the testing & providing conclusive proof back on the old Fon usage overcharging error thread that got locked after BT admitted the fault & (long since archived)
& it's great to see so many of the old guard who stood with us then are still here providing the depth of knowledge & years of experience that the "kids on the end of the phone" haven't yet gained.
