Message 1 of 9
Digital Voice - Handset and Voicemail
Never joined a ‘community’ before. I hope this info is useful to others. I would like to have known this before.
Recently renewed my BT contract (I had the full Monty anyway) and moved to Digital Voice with my package. I bought a BT phone with the deal (they actually sent 2). Set up without problems. I had some subsequent phone issues though in fairness BT helplines proved useful and answered several calls with only a brief delay. The following enacted / enabled via the helplines:
First, voicemail cannot be cancelled without losing Caller Protect (utterly absurd BT). I cancelled and lost all my blocked spam numbers. BT temporarily reinstated Caller Protect which reinstated Voicemail. I was then going to roll back my contract.  But what I now know is that you can delay Voicemail kicking-in so it is effectively useless. I tested it to more than 60 seconds and it did not kick in. I’ll settle for that. Fortunately I had a back-up list of my blocked spam numbers.
The handset has no headset  jack and I absolutely need that as I am invariably on the PC with callers. Hard of hearing and handy for that as well (utterly absurd BT). The phone does not include an option to permanently enhance the listening volume (utterly absurd BT). You can pre-set the ring volume very loud but not the listening volume. The latter needs to be adjusted with each caller.
My existing set of high quality Panasonic DECT phones work perfect when plugged into the back of the router in the (green) analogue converter but with the new phone ‘registered’ that is a different story. That sabotages my perfectly good phones. I could not then hear callers on my own phones. BT phone now de-registered and on its way back. Good riddance. My old phones now perfect and back to normal.
8 REPLIES 8
Message 2 of 9
Re: Digital Voice - Handset and Voicemail
Message 3 of 9
Odd then that I have both 2 Digital Voice handsets and a Panasonic DECT base station plugged into the green socket that co-exist just fine.
Message 4 of 9
Only my DECT base is plugged into the router green socket. BT literature does say that some third-party phones may be impacted by connection to the router. I acknowledge and accepted that risk. BUT, BT should make it more clear about the impact on voicemail and the extraordinary absence of a headphone jack as well as listening volume which is pitiful at its lowest (default) setting.  Had I liked the new phone I would have bought more to replace my dated stuff. Information could and shiould have been better. BT sending me a return bag for the phones.
I also volunteered to return the BT Disc as my BT broadband has always reached to the end on the drive no problem.
Thanks for taking the trouble to respond.
Message 5 of 9
I also have both - 2 Digital Voice handsets and a Gigaset DECT system base station plugged into the green socket that co-exist just fine too.
Message 6 of 9
It is all a wee bit academic now. The BT handset is not fit for the purpose anyway, which seems strange when set against the obvious quality of the router, hybrid connect, wi-fi disk and the service in general.
There are thousands out there working flat out, inventing stuff we do not need, yet we cannot get the simple stuff we do need and have been enjoying for years. The absence of a headset jack point and inability to raise the default setting for amplifying the listening experience, seems an absolute minimum common-sense specification to me.
That said, BT is taking that phone back no problem and are sending a postage bag for the purpose.
As my dated but quality Panasonic kit is working well as it has for years, I’ll stick with that. The telephone user (on all phones) can raise the earphone volume and it stays put until it is altered again. No need to navigate a menu to do that either. One simple multi-function button.
In time I may source a new set of telephones that can be guaranteed to be 100% compatibly with BT tech. I know what questions to ask first.
Message 7 of 9
All this is simply evidence of the managerial incompetence of  BT's senior executives. They couldn't run a bath.
The transition to Digital Voice reveals a complete failure to undertake a thorough preliminary  analysis of what would be iinvolved, to resolve any issues that the paying customers might encounter, to train staff and subscontractors' employees implementing the chamgeover, fully brief call centre staff, and ensure that all documentatio and online information is complete and accurate.
My landline was transferred to Digital Voice without warning or cosultation about what might be involved. Then, call centre staff didn't seem equipped, able or interested to define the issues I was encountering; equipment was supplied with inadequate documentation; inappropriate equipment was supplied;  and finally Techicians were sent who had limited expertise  and uninterested in resolving issues beyond their competence. More than six months later and there are still outstanding issues.  I just discovered this one, but only though a chance remark in a conversation with a cousin, an experienced computer engineer and systems manager, when the subject turned, as it often has done, to our experiences (mutually bad) with BT and the transfer to Diigital Voice.
Message 8 of 9
I had forgotten about my posting above. My dated Panasonic phones are working perfectly and have not and will not be replaced. I use a hands-free headset on all calls.
I receive an email when a bill is produced then when I arrive at the excruciatingly slow website, a message there tells me to call back later for my PDF if I have responded to the email too quick. It would be nice if we could opt-in  to have bills sent to the inbox to save having to log in each time and run the promotions gauntlet. This is all abysmal service.
I also use to good effect the nuisance call blocker (60 at the moment) but accessing that facility to enter a new number is always excruciatingly slow. Once passed the login page a number of clicks are required with delays (always) between clicks. I have to watch those three circles bouncing up and down and the pages jump about as well. Fortunately now nuisance callers (unrecognised numbers and I never answer them) are rare but it still wastes my time.
The excrutiatingly slow website only happens on BT.  One click shortcut options could easily be created.
Message 9 of 9
@absimj  Pretty much in keeping with the rest of the country then.
You should see the performance I’m having getting Sky to remove an account that was closed nine years ago for a relative who died six years ago.  They can’t locate the account, apparently.  Funny how I can still log into it then.
Sadly, it’s not just BT it’s rife throughout the country today.
