Message 11 of 18
Re: Digital Voice - Not Configured On Hub - BT can't seem to fix it !!!
Hi there
Did your issue ever get fixed? I am having exactly the same issue with BT and I am at the end of my tever! They keep insisting it is a local configuration issue or something I am doing wrong. Despite having had a BT home expert come and factory reset everything and got the same results as me and said it must be an issue on my account or at BT's end.
No one seems to be able to fix it which is crazy!
Did they fix yours and if so how?
I would really appreciate it if you could spare time to reply and let me know the outcome.
Thanks,
Steve
Message 12 of 18
Hi Steve, they eventually sorted it out after a couple of months ! It was some problem where they had two accounts for me, and were trying to apply the phone to the wrong one, and their system was getting confused.
They also said was something to do with porting over the phone from copper lines to the fibre. They never did manage to get my old phone number put on the account though.
I spent hours on the phone to them with people trying different updates and getting nowhere. I think you just have to keep on at them until you find a technician there who knows what they are doing
Message 13 of 18
Hi
I have been having this problem since my copper connection was converted to fibre on 19 July
Fortunately after  many calls to BT and being passed from pillar to post I was very lucky to manage to talk to an advisor who had a technical background
He carried out a number of tests and was of the opinion that the problem laid with the BT servers
He promised to call back today, Friday, when he informed me that the faults team had numerous calls regarding the same problem since I first reported it and it seemed to be a national issue and not anything the end user had under their control
The issue had been escalated to BT Wholesale to investigate and solve the problem
I was promised a call back on Monday to let me know the latest position
I will update this post when I have more information
Message 14 of 18
Hi
I am glad they resolved your issue.
Yes I know exactly what you mean. Mine was fixed this week. Eventually BT actually sent out an Open Reach engineer. The serial number on my FTTP Open Reach modem did not match their records. So I was getting someone elses service. Hence no Digital Voice and the slower speed. The Open Reach modem was replaced and correctly matched up with my account and hey presto it worked a treat.
Like you say it is just a case of keeping on at them until you either get someone who knows what they are doing or when they actually listen to what you tell them.
Thanks,
steve
Message 15 of 18
As promised an update to my earlier post
The issue has now been resolved after the problem was passed to the Technical Management Centre (TMC) and Data  Integrity (DI)
So if you have a similar problem you should push the advisor  to  escalate the problem to TMC and DI
Also ask the advisor to take responsibly for progressing the problem and to act as your primary contact
The advisor I have been talking to has been excellent and has agreed to call me in a weeks time to ensure noting has gone pear shaped
Message 16 of 18
HOW does one turn off smart setup
Message 17 of 18
smart setup is no longer shown on hubs so no need to turn off
Message 18 of 18
