Message 1 of 6
Digital Voice Voicemail Issue/Bug
Had DV for a little while now.
I've set up my voicemail so that I can dial in using my mobile & pick up any messages left. That part works fine.
When testing it out yesterday I called my home phone & left a message and then called again to pickup that message which was OK. I then deleted that message so now no messages remain.
All good so far, however, this morning my home phones are still showing a message counter & I get the interrupted dial tone indicating a message present but there isn't.
This is a software bug which will cause confusion.
There seems no way to clear this other than cancelling voicemail & setting it up again.
BT please fix this.
Edit: Just received an incoming call which clears it - very strange. Still a bug though.
@jac_95
Your posting of that same message really is not helpful to anyone really but does up your post count I guess.
5 REPLIES 5
Message 2 of 6
Re: Digital Voice Voicemail Issue/Bug
Message 3 of 6
Report it as a fault by logging into My BT.
Message 4 of 6
@TimCurtis
the post by @jac_95 is automatic when DV is mentioned.  This is helpful to new customers to DV and gives links to a great deal of information about DV which previously required repeating the same posts over and over to the same questions as nobody uses the search facility before posting their question
for existing forum members it just a matter of ignoring the standard post
Message 5 of 6
@RIC9380
Had a look at that but it's not a fault on my service as such, it's more a software bug that presumably will affect all users who use another phone to get their voicemail.
It could just be something in the firmware of the BT essential phones that once they've been set as having a voicemail it doesn't clear until there's an incoming call as calling 1571 didn't clear it.
Message 6 of 6
I take your point, @TimCurtis but reporting the issue directly to BT should mean that any bug in the software is noted and passed on to the relevant Team for further investigation. This only a consumer forum with very few BT staff moderating the posts.
